n-Stream
A world of music at your fingertips.
We’ve long argued the case for simplicity. Simpler hi-fi sounds better, is easier to use and ultimately more rewarding to live with. Our n-Stream app, available on iPad, iPhone and iPod touch, provides simple yet comprehensive control over both your music and the network-connected Naim components used to play it. You can adjust volume, skip, pause and play tracks, scroll through album art, create playlists and store favourite radio stations to be easily accessed later.
Share
Features
  • Controls Naim streaming products: NDS, NDX, ND5 XS, NAC-N 172 XS and Uniti all-in-one players
  • UPnP library browsing with album art support, search and playback controls
  • Input selection
  • Build and edit playlists
  • iRadio browsing, search, preset saving and selection
  • Full cover art support
  • Multiroom support including ‘party mode’ and group volume control
  • Automatic discovery of Naim streaming products
  • USB/iPod browsing and playback control
  • System automation compatibility provides volume and input control on compatible Naim devices
  • Rovi database support with layers of extended music data available
Technology & Craft
Music discovery
n-Stream also goes one step further than simple control, allowing you to browse your music in new and innovative ways. Integration with Rovi’s vast online music database adds layers of rich detail including biographies, discographies, reviews, similar music recommendations and more. It’s all up to you, of course: you can choose to explore those unexpected links between composers, performers and recordings, or you can simply hit ‘Play’ and leave the hard work to your system.
Newsletters Sign Up
