NAC-N 172 XS
The best of both worlds.
The NAC-N 172 XS defines a creative point at which two worlds collide – the traditional world of separate pre and power amplifiers, and the new world of network streaming.
For a start, the NAC-N 172 XS is a very high performance and inherently musical preamplifier. It combines a mix of analogue and digital audio inputs, a digitally-controlled analogue volume control, and analogue outputs to connect to a power amplifier. And it offers even more besides, because along with its conventional inputs it includes a front panel USB audio interface for iPad, iPod and iPhone input, and a wired or wireless network connection to access internet radio stations or stream from UPnP music servers.
Features
  • High quality preamplifier including digitally controlled analogue volume control
  • UPnP-enabled to allow streaming of audio files at up to 24bit/192kHz resolution from Naim hard disk servers, network-attached storage (NAS) devices or any home computer
  • Supports a broad range of music formats: WAV, FLAC, Apple Lossless, AIFF, AAC, Windows Media-formatted files, Ogg Vorbis and MP3
  • Six 24bit/192kHz-capable digital inputs (S/PDIF) to support optimum connection to external sources
  • Optional DAB+/DAB/FM radio module
  • vTuner 5* full-service internet radio
  • Multiroom & Party Mode compatible
  • iOS n-Stream App for intuitive control
Technology & Craft
As the first Naim streaming preamplifier, the NAC-N 172 XS introduces numerous innovative techniques for signal processing and isolation to ensure that each audio signal or stream is output with maximum fidelity. It employs a Burr Brown digital to analogue converter chip that offers the same performance as the one fitted to the NDX network player, and it benefits from all the filtering and signal management techniques that have brought Naim to the forefront of digital music in the home.
NAC-N 172 XS component selection is entirely optimised for sound quality and the XS style case construction helps minimise microphony by providing a rigid, non-resonant foundation for the electronics. Like every Naim product, fastidious attention to power supply noise and regulation, PCB layout and earthing topology, is a fundamental element of NAC-N 172 XS performance.
The result of all this extraordinary technology is extraordinary music reproduction that lives, breathes and satisfies. Integrate a NAC-N 172 XS in an existing audio system, or build a new pre/power amplifier system around it, and the world of high resolution audio, UPnP streaming, and the vast resource of internet radio can connect seamlessly with your existing world of CD and vinyl.
Product Specification
Audio Inputs
Attribute Name Attribute Value
Analogue Input
 1 x 5-pin DIN, 1 x RCA pair, 1 x front panel 3.5mm jack (combined optical)
Input Sensitivity
200mV
Input Impedance
30kΩ
Other Inputs
Digital Inputs:
5 x S/PDIF
2 x coaxial RCA        -
2 x optical TOSLINK
1 x 3.5mm front panel (mini-TOSLINK)
Sample Rates Maximum
192kHz (coaxial), 96kHz (optical)
UPnP
Ethernet (RJ45) or Wi-Fi
USB/iPod
1 front panel socket
Audio Outputs
Audio Outputs
1 x variable (4-pin DIN, 1 x RCA pair), 1 x fixed (1 x RCA pair)
Line Outputs Fixed (level)
1 x RCA pair
Line Outputs Variable (level)
775mV RMS
Output Impedance
<47Ω (variable outputs), <600Ω (fixed output)
Load Impedance
10kΩ (min.)
Other Outputs
Headphones Outputs: Stereo (front panel 3.5mm jack)
Frequency Response
5Hz - 40kHz
THD
0.015%
Signal-to-Noise Ratio
90dB
Crosstalk
80dB
Connectivity
Remote Control
Infra Red (RC5)
Remote Input
1 x rear panel 3.5mm jack (RC5 modulated and unmodulated)
USB
1 x USB Type Mini-B
Remote Output
Network
Ethernet (Cat5), Wi-Fi
Formats
CD Formats
Audio CD (Red Book, CD and CD-R)
Audio Formats
WAV (up to 32bit/192kHz)
AIFF (up to 32bit/192kHz)
FLAC (up to 24bit/192kHz)
ALAC (up to 24bit/96kHz)
WMA (up to 16bit/48kHz) must be WMA 9.2
Ogg Vorbis (up to 16bit/48kHz)
M4a (CBR and VBR up to 320kbit/s)
MP3 (CBR and VBR up to 320kbit/s)
Playlists (M3U, PLS)
Internet Radio Provider
vTuner 5* full service
Internet Radio formats
Windows Media-formatted content, MP3, ACC, Ogg Vorbis streams and MMS
DAB Tuning Range
Band III and L Band
FM Tuning Range
87.5 - 108MHz
User Control
Front Panel
Volume control, logo touch-sensitive mute function and nine button matrix
Handheld
Remote handset included and optional n-Stream app for iPad, iPhone and iPod Touch from App Store.
Power
Supply Voltage
100V, 115V, 230V; 50 or 60Hz
Upgrades
Other
Hi-Line, Power-Line, any power amplifier
Physical
Dimensions (HxWxD)
70 x 432 x 301 mm
Weight
5.65 kg
Supplied with
NaimUniti Remote Control
Finish
Front
Brushed and black anodised
Case
Black powder coated
Suggested System
A Naim Retailer will recommend the right system for you, however you may choose to partner the NAC-N 172 XS with the following as a start:
Ovator S-400
Ovator
NAP 155 XS Power Amplifier
NAP 155 XS
XS Series
Manuals & Downloads
Reviews & Awards
Queen's Award for Innovation
Hi-Fi World Five Globes
Best Streamer £1000 - £2000
Newsletters Sign Up
