NAP V145
Boost your AV system.
The NAP V145 is our mono power amplifier for use with multichannel AV systems. It shares the circuit layout and key components of our acclaimed NAP 250 and is every bit as transparent and articulate, yet provides even greater dynamics.
During the years of research that went into the flagship NAP 500, many technical developments came about that have been successfully applied to the NAP V145. Based around the circuit topology of the latest NAP 250, the NAP V145 provides even greater dynamic capabilities and enhanced audio performance, resulting in the perfect solution for high quality multi-channel or active high-end systems.
Like the NAP 500, the NAP V145 uses a new circuit design with improved earthing arrangements, built on a high quality, anti-resonance main audio circuit board. It uses the same 007 transistors that were custom-designed for the NAP 500. These outstanding components each provide up to 80 Amps and 350 watts, negating the need to use parallel pairs of transistors (which always have a negative effect on sound). Additional 007 transistors are used in the fully regulated power supply, ensuring the best performance.
Anti-vibration, resonance-controlling feet serve to protect the sensitive internal components from resonance and microphonic vibration. A new top-quality transformer is used providing the ability to swing a massive 400 VA on transients. Furthermore, the NAP V145 is stable into any load and can drive a 2-Ohm load for long periods of time.
Features
  • 80W (mono) output into 8 ohms
  • Large custom-designed transformer providing 400VA of transient power
  • Advanced 007 output transistors, as used in our reference NAP 500 power amplifier
Product Specification
Audio Inputs
Attribute Name Attribute Value
Analogue Input
1 x XLR
Input Impedance
18kΩ
Audio Outputs
Gain
+29dB
Frequency Response
 -3dB at 3Hz - 50kHz
Minimum Load Impedance
Speaker Outputs
Speaker Outputs
L & R, 4mm “banana” sockets
Power Output
80W (mono amplifier), 8Ω
Transient
400VA
Power
Mains Supply
100V, 115V, 230V; 50 or 60Hz
Physical
Dimensions (HxWxD)
87 x 432 x 314 mm
Weight
15.8 kg
Shipping Dimensions
240 x 590 x 500 mm
Shipping Weight
17.3 kg
Supplied with
Standard Interconnect
Finish
Front
Brushed and black anodised
Case
Black powder coated
Manuals & Downloads
Newsletters Sign Up
