ND5 XS Network Player
ND5 XS
Streamlined for digital music.
The ND5 XS is our introduction to network music streaming, but still benefits from classic Naim audio engineering principles and fastidious attention to detail in every aspect of its layout and design.
It also loses none of the flexibility or functionality of its illustrious siblings. High-resolution UPnP network streaming, USB/iPod playback, access to thousands of internet radio stations, DAB/FM radio, digital inputs for external sources, multiroom streaming and a bespoke iOS control app will get you listening to more music than ever before.
Features
  • UPnP-enabled to allow streaming of audio files at up to 24bit/192kHz resolution from Naim hard disk servers, network-attached storage (NAS) devices or any home computer
  • Supports a broad range of music formats: WAV, FLAC, Apple Lossless, AIFF, AAC, Windows Media-formatted files, Ogg Vorbis and MP3. Gapless playback on all lossless file formats and on most compressed music
  • Three 24bit/192kHz capable digital inputs (S/PDIF) to support optimum connection to external sources
  • Front-panel USB port for replay of MP3 player/iPod and USB-stored audio
  • vTuner 5* full-service internet radio
  • Optional DAB+/DAB/FM radio module
  • Multiroom & Party Mode compatible
  • iOS n-Stream for intuitive control
Technology & Craft
Like the NDX, the ND5 XS is one of the most technically advanced and accomplished of all Naim products. The use of numerous innovative techniques for electronic signal processing and isolation ensure that each digital audio data stream is delivered to the ND5 XS outputs with maximum fidelity. The ND5 XS uses the same RAM buffer and master-clock jitter removal technique of the Naim DAC and all the oversampling, filtering and signal management techniques that have brought Naim to the forefront of digital music in the home.
And the result of all this extraordinary technology is extraordinary music reproduction. Connect an ND5 XS to your existing audio system and the world of high resolution audio downloads, UPnP streaming, and the vast resource of internet radio are yours for the listening. And it's a world where music from any source will live, breath and satisfy - completely.
Please note: only current "Classic" style XPS power supplies can be used with the ND5 XS. Older "Olive" style XPS units are incompatible and cannot be used.
Product Specification
Audio Inputs
Attribute Name Attribute Value
Digital (S/PDIF)
3 x S/PDIF:
   - 1 x coaxial BNC - up to 24bits/192kHz
   - 1 x coaxial RCA - up to 24bits/192kHz
   - 1 x optical TOSLINK - up to 24bits/96kHz
USB
1 x front panel Type A socket (also used for iPod)
Antenna
Wi-Fi (802.11 g or n at 2.4GHz), F type (plus PAL adapter) on tuner version
UPnP
Wired Ethernet (RJ45) or Wi-Fi
Audio Outputs
Digital (S/PDIF)
1 x BNC (75Ω)
Analogue
1 x DIN and 1 x RCA, 2.1V RMS at 1 kHz
Output Impedance
22Ω (max.)
Load Impedance
10kΩ (min.)
Frequency Response
10Hz - 20kHz, +0.1/−0.5dB
THD + N
<0.02%, 10Hz - 20kHz at full level
Connectivity
Remote Control
Infra Red (RC5)
Remote Input
1 x rear panel 3.5mm jack (RC5 modulated and unmodulated)
Remote Output
2 x rear panel 3.5mm jack (RC5 modulated or unmodulated)
Updates
1 x USB Type Mini-B
Formats
Audio Formats
WAV (up to 24bit/192kHz)
AIFF (up to 24bit/192kHz)
FLAC (up to 24bit/192kHz)
ALAC (up to 24bit/96kHz)
WMA (up to 16bit/48kHz) must be WMA 9.2
Ogg Vorbis (up to 16bit/48kHz)
M4a (CBR and VBR up to 320kbit/s)
MP3 (CBR and VBR up to 320kbit/s)
Playlists (M3U, PLS)
Internet Radio Provider
vTuner 5* full service
Multiroom
Master: Will stream WAV, FLAC and AIFF (up to 24bit/48kHz), ALAC (up to 16bit/44.1kHz), AAC and MP3 (up to 16bit/48kHz) files only as MP3 320kbps quality.
DAB Tuning Range
(optional module) Band III and L Band
FM Tuning Range
(optional module) 87.5 - 108MHz
User Control
Front Panel
Nine button matrix
Handheld
Remote handset included and optional n-Stream app for iPad, iPhone and iPod Touch available from the App Store
Upgrades
Power Supply
XP5 XS, XPS, 555 PS
Other
DAC digital to analogue converter, Hi-Line, Power-Line
Power
Supply Voltage
100V, 115V, 230V; 50 or 60Hz
Power Consumption
60VA (max.)
Physical
Dimensions (HxWxD)
70 x 432 x 301 mm
Weight
6.5 kg
Supplied with
Uniti Remote Control, Standard Interconnect
Suggested System
A Naim Retailer will recommend the right system for you, however you may choose to partner the ND5 XS with the following as a start:
Ovator S-400
Ovator
NAP 155 XS Power Amplifier
NAP 155 XS
XS Series
NAC 152 XS
XS Series
Manuals & Downloads
Reviews & Awards
Queen's Award for Innovation
AVForums Highly Recommended
HiFi Choice Winner Award 2011
Newsletters Sign Up
