NaimUniti 2
The NaimUniti 2 is the new and improved version of our original, revolutionary all-in-one player. It spawned an entire range of accessible and versatile music streaming systems that offer the kind of stunning sound quality previously thought possible only through separates.
As well as being able to play UPnP streams at up to 24bit/192kHz resolution via a wired or wireless connection, NaimUniti 2 incorporates a CD player, a 70W per channel amplifier, six digital inputs, built in Spotify Connect, Bluetooth (aptX) connectivity, native support for TIDAL lossless music streaming service, a DAB+/DAB/FM and internet radio tuner as well as a USB interface that enables playback from an iPod or high-resolution digital audio from a USB memory stick. Just add speakers.
- UPnP-enabled to allow streaming of audio files at up to 24bit/192kHz resolution from Naim Audio hard disk servers, network-attached storage (NAS) devices or any home computer
- CD playback through unique Naim Audio radial arc disc tray
- Integrated 70W per channel amplifier shares design DNA with iconic NAIT integrated amp
- Supports a broad range of music formats: WAV, FLAC, Apple Lossless, AIFF, AAC, Windows Media-formatted files, Ogg Vorbis and MP3
- Five 24bit/192kHz-capable digital inputs (S/PDIF) to support optimum connection to external sources
- Spotify Connect built-in to stream millions of songs from the world’s most popular streaming service
- Native support for TIDAL streaming service with free 90 day trial of lossless HiFi tier
- Bluetooth connectivity with aptX codec for quality audio playback
- DAB+/DAB/FM radio module
- vTuner 5* full-service internet radio
- Multiroom & Party Mode compatible
- iOS and Android Naim Audio app for intuitive control
NaimUniti 2 has an analogue heart. Its NAIT 5si-derived integrated amplifier beats true to our long established design philosophies and is the foundation of the NaimUniti 2's audio quality.
But in parallel with audio quality, it is the immense digital versatility of NaimUniti 2 that sets it apart from any other all-in-one audio product. Alongside CD audio, FM and DAB radio, and internet radio streams at multiple bit rates, NaimUniti 2 can play audio files in MP3, Windows Media-formatted content, AAC, Apple Lossless, FLAC and WAV formats. And thanks to an internal DAC with its five 24bit/192kHz-capable S/PDIF inputs, external digital audio sources, such as satellite TVs or games consoles, are a breeze for NaimUniti 2.
Analogue audio connectivity is not forgotten either. Five analogue inputs can accommodate CD players or portable music players via rear panel phono sockets, a DIN phone input and a front-panel mini-jack. And a preamplifier output means that with the addition of an external power amplifier, or even a subwoofer, NaimUniti 2 can become the heart of a very wide bandwidth audio system. And when you want to listen privately, a front panel headphone socket makes such selfishness all too easy.
So as well as offering all-in-one functionality, NaimUniti 2 is the perfect audio hub.
Product Specification
Attribute Value | |
Other |
Spotify Connect, Bluetooth (SBC, AAC and aptX Classic, aptX Low Latency) |
Antenna |
Wi-Fi (802.11 b/g or n at 2.4GHz), F type (plus PAL adapter) |
USB |
1 x front panel Type A socket (also used for iPod) |
Analogue |
1 x 4-pin DIN (includes +24V output ), 3 x RCA pair, 1 x front panel 3.5mm jack (combined optical) |
Digital (S/PDIF) |
5 x S/PDIF: |
Input Sensitivity |
Rear: 275mV, Front: 125mV |
Attribute Value | |
Headphone Output |
1 x 3.5mm jack |
Sub Output |
2 x RCA (mono) |
Line Output |
1 x RCA pair |
Load Impedance |
10kΩ min |
Output Impedance |
22Ω |
Analogue |
Speaker output, line output (L + R RCA), sub output (2 mono outputs via RCA), preamp output (4-pin DIN) |
Digital (S/PDIF) |
No |
Power Output |
70W per channel into 8Ω, 100W per channel into 4Ω |
Signal-to-Noise Ratio |
82dB A-WTD ref 1W 8Ω |
Frequency Response |
10Hz - 20kHz, +0.1/-0.5dB |
Attribute Value | |
Updates |
1 x USB Type Mini-B |
Remote Output |
No |
Remote Input |
1 x rear panel 3.5mm jack (RC5 modulated and unmodulated) |
Attribute Value | |
CD Formats |
Audio CD (Red Book, CD and CD-R) |
Multiroom |
Master: Will stream WAV, FLAC and AIFF (up to 24bit/48kHz), ALAC (up to 16bit/44.1kHz), AAC and MP3 (up to 16bit/48kHz) files only as MP3 320kbps quality. |
FM Tuning Range |
87.5 - 108MHz |
DAB Tuning Range |
Band III and L Brand |
Internet Radio Formats |
Windows Media-formatted content, MP3, ACC, Ogg Vorbis streams and MMS |
Internet Radio Provider |
vTuner 5* full service |
Audio Formats |
WAV (up to 24bit/192kHz) |
Attribute Value | |
Weight |
11.7 kg |
Dimensions (HxWxD) |
87 x 432 x 314 mm |
Attribute Value | |
Power Consumption |
400VA (max.) |
Supply Voltage |
100V, 115V, 230V; 50 or 60 Hz |
Attribute Value | |
Supplied with |
Uniti Remote Control |
Attribute Value | |
Other |
Power-Line, WA5 antenna |
Amplification |
External power amplifier |
Attribute Value | |
Front Panel |
Nine button matrix |
Handheld |
Remote handset included and optional Naim app for iOS and Android. |
Remote Control |
Infra Red (RC5) |
Manuals & Downloads
Software Download / Update
Brochures
Product Manuals
Manual Supplement
Quick Start Guides
User Help Guide
Reviews & Awards
Newsletters Sign Up
