NAIT XS 2 Integrated Amplifier
NAIT XS 2
Discontinued
The NAIT XS 2 offers much of the performance of our reference quality SUPERNAIT 2 in a simpler, slimmer package combining a 70W power amplifier with six analogue inputs. Its high performance preamplifier stage is as transparent as you would expect from a Naim Audio amplifier, and it also shares the single-ended class-A headphone output of its larger sibling.
The NAIT XS 2 can be upgraded with our external power supplies, power amplifiers and even phono stages to become the musical heart of a modern music system to get the best from digital, CD, vinyl and AV sources.
Share
Features
  • 70W per channel power output
  • Six inputs with support for both DIN and RCA connections
  • 1/4” (6.35mm) headphone output and high quality class-A headphone amplifier
  • Ceramic heat sink isolation for improved sound quality on power and preamp section
  • AV bypass mode for simple connection to an existing AV system
  • Preamplifier, power amplifier and subwoofer connections
Technology & Craft
At 70 Watts per channel, the NAIT XS 2 is more powerful than its NAIT XS predecessor. It also features numerous refinements to enhance its music making still further: ceramic heatsink technology, constant current source drive electronics, a reconfigured internal layout to optimise signal paths and custom manufactured film style capacitors in all audio critical locations.
Constructed in a slimline aluminium enclosure, the NAIT XS 2 provides six analogue inputs and the same innovative Class A headphone amplifier as the SUPERNAIT 2. With any amplifier, however, the proof of its technology is in the listening. The NAIT XS 2 is both powerful and delicate, dynamic and even-handed. It does everything the music asks and delivers everything that a Naim Audio amplifier should.
Product Specification
Audio Inputs
Attribute Value
Input Impedance
47kΩ
Analogue Input
4 x DIN/RCA pair, 1 x RCA pair, 1 x DIN (for Naim phono amplifier)
Input Sensitivity
130mV
Audio Outputs
Attribute Value
Audio Outputs
Speakers, record, preamp and variable sub
Other Outputs
Headphone, 1/4" jack
Line Outputs Variable (level)
775mV, <50Ω
Line Outputs Fixed (level)
130mV, 600Ω
Power Outputs
Connectivity
Attribute Value
Updates
1 x USB Type Mini-B
Remote Input
1 x 3.5mm jack on rear (RC5 modulated/unmodulated)
Finish
Attribute Value
Case
Black powder coated
Front
Brushed and black anodised
Physical
Attribute Value
Shipping Weight
10.35 kg
Shipping Dimensions
200 x 590 x 500 mm
Weight
8.4 kg
Dimensions (HxWxD)
70 x 432 x 301 mm
Power
Attribute Value
Power Consumption (max.)
290VA (max.)
Mains Supply
100V, 115V, 230V; 50 or 60Hz
Power Consumption (quiescent)
20VA
Speaker Outputs
Attribute Value
Power Output
70W/channel, 8Ω
Supplied with
Attribute Value
Supplied with
NARCOM-4 Remote Control, Power-Line Lite mains cable (UK denominations only)
User Control
Attribute Value
Front Panel
Volume Control, seven button matrix
Remote Control
Infra Red (RC5)
Suggested System
A Naim Audio Retailer will recommend the right system for you, however you may choose to partner the NAIT XS 2 with the following as a start:
  • ND5 XS
  • CD5 XS
  • Aria 900
Manuals & Downloads
Newsletters Sign Up
