NAP 100 Power Amplifier
NAP 100 Discontinued
Compact Size, Expansive Sound
  • bvseo_sdk, p_sdk, 3.2.1
  • CLOUD, getAggregateRating, 5.86ms
  • REVIEWS, PRODUCT
  • bvseo-msg: HTTP status code of 404 was returned; HTTP status code of 404 was returned;
The NAP 100 has been discontinued but remains a classic expression of traditional Naim Audio power amplifier engineering. While its dimensions are conveniently compact – just a mere 20cm wide – its performance is seriously dynamic and expansive.
The NAP 100 is perfect for a number of applications, adding a dose of Naim Audio musicality to a wide variety of systems. Paired with our DAC-V1 digital-to-analogue converter, it becomes the power behind a high-end system to unleash the music from your PC or Mac. Add a UnitiServe to the equation and you create a full hi-fi system that divorces your listening experience from the desktop and allows you complete control from our n-Serve iOS app.
Share
Features
  • 50W per channel output into 8 ohms
  • Dual mono power amplifier design
  • Audiophile grade hand-selected components
  • Linear power supply with a large toroidal transformer
  • Pair with the DAC-V1 and UnitiServe for compact, high-end music system
NAP 100 Power Amplifier - Rear View
Technology & Craft
Despite its small size, the NAP 100 packs a serious punch when it comes to sound quality. Delivering 50 watts per channel into 8 Ohms, and 75 watts into 4 Ohms, its dual mono design is based on the circuit topology found in our reference all-in-one player, the SuperUniti.
Our engineers also took inspiration from classic Naim Audio power amplifier design in developing the NAP 100. A large toroidal transformer and hand-matched, hand-wired critical componentry allow it to bring new levels of clarity and vitality to your music.
Product Specification
Audio Inputs
Attribute Value
Input Impedance
18kΩ
Analogue Input
1 x 4-pin DIN, 1 x RCA pair
Audio Outputs
Attribute Value
Minimum Load Impedance
Frequency Response
 -3dB at 3.5Hz - 69kHz
Gain
+29dB
Finish
Attribute Value
Case
Black powder coated
Front
Black powder coated
Physical
Attribute Value
Shipping Weight
7.6 kg
Shipping Dimensions
210 x 280 x 410 mm
Weight
5.1 kg
Dimensions (HxWxD)
87 x 207 x 314 mm
Power
Attribute Value
Mains Supply
115V or 230V, 50 or 60Hz
Power Consumption
260VA
Power Consumption (quiescent)
15VA
Speaker Outputs
Attribute Value
Speaker Outputs
50W per channel into 8Ω, 75W per channel into 4Ω
Speaker Outputs
L & R, 4mm “banana” sockets
Supplied with
Attribute Value
Supplied with
SNAIC, Power-Line Lite mains cable (UK denominations only)
Suggested System
A Naim Audio Retailer will recommend the right system for you, however you may choose to partner the NAP 100 with the following as a start:
  • Uniti Core
  • DAC-V1
  • Aria 900
Manuals & Downloads
Reviews & Awards
Latest Reviews
Gramophone, May 2013
"Just add speakers and a computer for the ultimate desktop system."
AVForums, May 2013
“The Naim delivered a beautifully poised performance with a precise and detailed delivery. As a result it was wonderfully musical, with a smooth but lively sound that retained plenty of dynamism.”
IT ProPortal, Apr 2013
"The DAC-V1 represents Naim’s first foray into asynchronous USB, and as debuts go, this one is pretty spectacular."
Awards
Best Buy
AVForums Highly Recommended
Hi-Fi Choice Recommended
Stars of CES 2013
Book a Demo
Find Your Nearest Retailer
Please complete the form below to arrange an appointment with your chosen retailer.
By submitting your contact details, you agree for us to share your details with our retail partners, who will contact you directly to arrange your appointment. For full details on how your data is shared please review our privacy policy
Customer Reviews
  • CLOUD, getReviews, 174.39ms
  • REVIEWS, PRODUCT
Newsletters Sign Up
