SUPERNAIT 2 Integrated Amplifier
SUPERNAIT 2
The pinnacle of integrated performance.
It’s been almost 30 years since we designed our first integrated amplifier: time enough to define and refine the technical ingredients essential to high-end performance. Our reference quality SUPERNAIT 2 represents the pinnacle of this accumulated knowledge. It is both the most sophisticated integrated amplifier we’ve ever created and a classic Naim Audio product, shot through with the soul of the original, iconic NAIT.
SUPERNAIT 2 combines an 80W power amplifier with six individually decoupled input sockets and borrows advanced technology from Naim Audio’s flagship preamplifier, the NAC 552. In employing the latest Naim Audio DR (Discrete Regulator) circuits in its power supply, it sits right at the forefront of Naim Audio amplifier technology.
Features
  • 80W per channel power output
  • Six individually decoupled and hand-wired inputs with support for both DIN and RCA connections
  • Built in Naim Audio DR (Discrete Regulator) power supply for preamplifier section
  • 1/4” (6.35mm) headphone output and high quality class-A headphone amplifier
  • Ceramic heat sink isolation for improved sound quality on power and preamp sections
  • Dedicated subwoofer output
  • Powered input for use with StageLine or SuperLine phono stage
Technology & Craft
SUPERNAIT 2 includes a Class A preamp output stage which doubles as a headphone amplifier, ceramic heatsink technology that minimises capacitive coupling between the chassis and output transistors for optimum sound quality. Its inputs are each individually decoupled and hand-wired to minimise noise and interference while internal switching employs ultra-low-noise, constant current sources which are derived directly from the electronic design of the flagship NAC 552 preamplifier.
Set at the core of every SUPERNAIT 2 is a custom-designed toroidal transformer featuring seven separate windings. This can be further upgraded with one of our external HiCap or SuperCap power supplies. Even the analogue delights of vinyl are yours to explore: simply add a StageLine or SuperLine phono stage. The SUPERNAIT 2 doesn't miss a trick or a beat.
It doesn't miss any music either. The SUPERNAIT 2 is never fazed by the demands of either speaker or music. It simply delivers dynamic, detailed and engaging music that can’t fail to move you.
Product Specification
Power
Attribute Value
Mains Supply
100V, 115V, 230V; 50 or 60Hz
Power Consumption (quiescent)
10VA
Audio Outputs
Attribute Value
Audio Outputs
Speakers, record, preamp and variable sub
Other Outputs
Headphone, 1/4" jack
Line Outputs Variable (level)
775mV, <50Ω
Line Outputs Fixed (level)
130mV, 600Ω
Power Outputs
Naim phono amplifier
Physical
Attribute Value
Shipping Dimensions
240 x 590 x 500 mm
Weight
12.8 kg
Weight
15.3 kg
Dimensions (HxWxD)
87 x 432 x 314 mm
User Control
Attribute Value
Front Panel
Volume Control, Balance Control, seven button matrix
Connectivity
Attribute Value
Updates
1 x USB Type Mini-B
Remote Input
1 x 3.5mm jack on rear (RC5 modulated/unmodulated)
Remote Control
Infra Red (RC5)
Speaker Outputs
Attribute Value
Power Output
80W/channel, 8Ω
Finish
Attribute Value
Case
Black powder coated
Front
Brushed and black anodised
Supplied with
Attribute Value
Supplied with
NARCOM-4 Remote Control, Power-Line Lite mains cable (UK denominations only)
Audio Inputs
Attribute Value
Input Impedance
47kΩ
Analogue Input
4 x DIN/RCA pair, 1 x RCA pair, 1 x DIN (for Naim phono amplifier)
Input Sensitivity
130mV
Suggested System
A Naim Audio Retailer will recommend the right system for you, however you may choose to partner the SUPERNAIT 2 with the following as a start:
  • Sopra
  • NDX
  • CDX2
Manuals & Downloads
Book a Demo
Find Your Nearest Retailer
Please complete the form below to arrange an appointment with your chosen retailer.
By submitting your contact details, you automatically agree for us to share your details with our retail partners, who will contact you directly to arrange your appointment. For full details on how your data is shared please review our privacy policy
Newsletters Sign Up
