UnitiQute 2
Everything about UnitiQute 2 is cute. It could not have been given any other name. It’s a compact, multi-source, all-in-one player that streams music at up to 24bit/192kHz resolutions over UPnP™. At its heart lies a 30W integrated amplifier that will drive a wide range of bookshelf or standmount speakers and fill your room with music. Our Naim Audio app for iOS and Android integrated with TIDAL, lossless audio streaming service makes the package even more appealing.
- UPnP-enabled to allow streaming of audio files at up to 24bit/192kHz resolution from Naim Audio hard disk servers, network-attached storage (NAS) devices or any home computer
- Integrated 30W per channel amplifier shares design DNA with iconic NAIT integrated amp
- Supports a broad range of music formats: WAV, FLAC, Apple Lossless, AIFF, AAC, Windows Media-formatted files, Ogg Vorbis and MP3
- Six 24bit/192kHz-capable digital inputs (S/PDIF) to support optimum connection to external sources
- Spotify Connect built-in to stream millions of songs from the world’s most popular streaming service
- Native support for TIDAL lossless audio streaming service with free 90 day trial of lossless HiFi tier
- Bluetooth connectivity with aptX codec for quality audio playback
- DAB+/DAB/FM radio module
- vTuner 5* full-service internet radio
- Multiroom & Party Mode compatible
- iOS and Android Naim Audio app for intuitive control
UnitiQute 2 may be compact but it packs some serious audio technology within its elegant extruded and die-cast aluminium enclosure. Its digital audio performance profits immeasurably from literally decades of high-end digital audio and amplification knowhow.
The integrated amplifier section of the UnitiQute 2 has been influenced heavily by the iconic NAIT range while it also benefits from Naim Audio advancements in digital streaming technology that won a Queen’s Award for Innovation in 2014. Its digital connectivity also means that as well as offering all-in-one functionality operating as a digital hub for external digital sources, games consoles or digital TV audio for example, it can also output its internal sources or external digital signals to an external DAC for even higher audio quality.
Analogue audio connectivity is not forgotten either. Two analogue inputs can accommodate CD players or portable music players via rear panel phono sockets and a front-panel mini-jack. And a preamplifier output means that with the addition of an external power amplifier, or even a sub-woofer, UnitiQute 2 can become the heart of a very wide bandwidth audio system. And when you want to listen privately, a front panel headphone socket makes such selfishness all too easy.
Product Specification
Attribute Value | |
Other |
Spotify Connect, Bluetooth (SBC, AAC and aptX Classic, aptX Low Latency) |
Antenna |
Wi-Fi (802.11 g or n at 2.4GHz), F type (plus PAL adapter) |
Antenna |
Wi-Fi, F type (plus PAL adapter) |
USB |
1 x front panel Type A socket (also used for iPod) |
Analogue |
1 x RCA pair, 1 x front panel 3.5mm jack (combined optical) |
Digital (S/PDIF) |
5 x S/PDIF: |
Input Sensitivity |
270mV at 47kΩ |
Attribute Value | |
Headphone Output |
1 x 3.5mm jack |
Load Impedance |
10kΩ min |
Output Impedance |
22Ω max |
Analogue |
Speaker output, preamp output (RCA) |
Digital (S/PDIF) |
1 x BNC (75Ω) |
Power Output |
30W per channel into 8Ω, 45W per channel into 4Ω |
Signal-to-Noise Ratio |
80dB |
Frequency Response |
20Hz - 50kHz, +0.1/−0.5dB |
Attribute Value | |
Multiroom |
Master: Will stream WAV, FLAC and AIFF (up to 24bit/48kHz), ALAC (up to 16bit/44.1kHz), AAC and MP3 (up to 16bit/48kHz) files only as MP3 320kbps quality. |
FM Tuning Range |
87.5 - 108MHz |
DAB Tuning Range |
Band III and L Band |
Internet Radio Formats |
Windows Media-formatted content, MP3, ACC, Ogg Vorbis streams and MMS |
Internet Radio Provider |
vTuner 5* full service |
Audio Formats |
WAV (up to 24bit/192kHz) |
Attribute Value | |
Weight |
5.6 kg |
Dimensions (HxWxD) |
87 x 207 x 314 mm |
Attribute Value | |
Power Consumption |
25VA (quiescent), 200VA (max.) |
Supply Voltage |
100V, 115V, 230V; 50 or 60Hz |
Attribute Value | |
Supplied with |
Uniti Remote Control |
Attribute Value | |
Other |
Power-Line, WA5 antenna |
Amplification |
External power amplifier |
Attribute Value | |
Front Panel |
Logo touch-sensitive mute and volume control function |
Handheld |
Remote handset included and optional Naim app for iOS and Android. |
Manuals & Downloads
Software Download / Update
Brochures
Manual Supplement
Product Manuals
Quick Start Guides
Reviews & Awards
Newsletters Sign Up
