DAC-V1 Digital To Analogue Converter
DAC-V1
Discontinued | Convert ordinary to extraordinary.
  • bvseo_sdk, p_sdk, 3.2.1
  • CLOUD, getAggregateRating, 7.09ms
  • REVIEWS, PRODUCT
  • bvseo-msg: HTTP status code of 404 was returned; HTTP status code of 404 was returned;
Our newest DAC is perfectly optimized for modern digital listening. It features an asynchronous USB input – ideal for getting stunning sound quality from your computer. DAC-V1’s single-ended class-A headphone amplifier affords it added versatility. The output stages of this amplifier are kept as pure as possible, ensuring outstanding sound quality for headphone listening. The DAC-V1 is now DSD compatible and able to play 64 (2.8MHz sample rate) and 128 files (5.6MHz sample rate); the upgrade required significant optimisation of the core DSP code which has also improved sound quality.
The DAC-V1’s compact size makes it perfectly suited as a desktop companion to your Mac or PC, but its exceptional musicality means it will complement our standard-width hi-fi components just as well. Combine it with our UnitiServe hard disk music server and its matching NAP 100 power amplifier and you’ll create a stunning hi-fi system from just three compact boxes.
Share
Features
  • High-speed asynchronous USB input up to 24bit/384kHz
  • Five S/PDIF inputs for digital sources like games consoles, set top boxes and hard disk servers
  • Selectable fixed or variable analogue outputs (DIN or RCA)
  • Naim Audio digitally controlled analogue volume control for performance and precision 40bit SHARC DSP chip handling filtering and oversampling
  • Single-ended class-A headphone amplifier output
Technology & Craft
Asynchronous USB Explained
Digital audio isn’t just about the data – 0s and 1s – and ensuring that each sample value is accurately converted into a corresponding output voltage. Also vital to achieving the highest fidelity is ensuring that each successive sample is reproduced at a precise time interval from those around it. If that time interval varies – an effect known as jitter – then the output waveform will be distorted. To prevent this, the master clock that controls the process should, ideally, be placed right next to the digital to analogue converter circuitry, not remote from it. Asynchronous mode USB provides for this because it allows data to be ‘pulled’ from the source as required, whereas in other modes the data is ‘pushed’ down the interface under control of the far inferior and distant clock in the computer.
World class headphone amplifier
The single-ended Class-A headphone amplifier of the DAC-V1 cleverly uses the pre-amp output amplifier for headphone drive. The moment headphones are plugged in, the output current drive is automatically turned up five times to give dynamic drive for all headphone impedances. The amplifier runs from a high voltage power supply so has the ability to drive high impedance headphones with the voltage swing they require for open and dynamic sound. The result is the audio stages are kept as simple and pure as possible for both normal and headphone modes.
Product Specification
Audio Inputs
Attribute Value
Digital
5 x S/PDIF:
   - 1 x coaxial BNC
   - 2 x coaxial RCA
   - 2 x optical TOSLINK
USB
1 x asynchronous USB (type B socket)
Audio Outputs
Attribute Value
Headphone Output
1⁄4 inch (6.35mm) TRS Socket
Line Output
Variable or 2.1V RMS fixed
Load Impedance
10kΩ (min)
Output Impedance
<10Ω
Analogue
2 (RCA and DIN) Variable Pre-amp Output, Line Output Fixed: 2.1V RMS
THD
<0.002%
Frequency Response
10Hz – 20kHz, +0.1/-0.5dB
Operating System
Attribute Value
Mac OSX
OSX 10.7 and above (up to 24bit/384kHz)
Windows
Windows 7 and 8 (up to 24bit/348kHz), Custom driver available
Physical
Attribute Value
Weight
4.3 kg
Dimensions (HxWxD)
87 x 207 x 314 mm
Power
Attribute Value
Power Consumption
<17VA (max.)
Supply Voltage
115V or 230V, 50 or 60Hz
Sample Rates Supported
Attribute Value
USB
44.1kHz - 384kHz (16 to 24bit)
S/PDIF
32kHz - 192kHz (up to 24bit)
Supplied with
Attribute Value
Supplied with
Remote handset included, Power-Line Lite mains cable (UK denominations only)
User Control
Attribute Value
IR Input
Front panel
Front Panel
Front panel buttons and touch-sensitive logo mute function
Handheld
Remote handset
Remote Control
Infra Red (RC5)
Manuals & Downloads
Reviews & Awards
Latest Reviews
Naim DAC-V1 l What Hi-Fi?, Feb 2016
'We plug our headphones in and are greeted with Naim’s signature sound, which balances the ability to be hard-driving, focused and dramatic with the subtlety and finesse needed to handle more delicate pieces of music.'
Hi-Fi Choice, Dec 2013
"Another masterful showing from Naim. It takes the good bits from the pricier Naim DAC, adds an excellent asynchronous USB implementation and a volume control and the result is a sound that's good enough to let rip into most speakers."
What Hi-Fi? Sound & Vision, Jul 2013
The DAC-V1 is nothing short of a triumph for Naim.
Gramophone, May 2013
"Just add speakers and a computer for the ultimate desktop system."
AVForums, May 2013
“The Naim delivered a beautifully poised performance with a precise and detailed delivery. As a result it was wonderfully musical, with a smooth but lively sound that retained plenty of dynamism.”
IT ProPortal, Apr 2013
"The DAC-V1 represents Naim’s first foray into asynchronous USB, and as debuts go, this one is pretty spectacular."
Hi-Fi Choice, Apr 2013
"Another masterful showing from Naim... a package that's even greater than the sum of the parts - and great value too."
MSN Tech, Feb 2013
"If you listen to music most of the day, think about the hours you’ll spend rediscovering your favourite albums during your working week."
Awards
5 Stars
Test Winner
Best Buy
AVForums Highly Recommended
Hi-Fi Choice Recommended
Stars of CES 2013
Book a Demo
Find Your Nearest Retailer
Please complete the form below to arrange an appointment with your chosen retailer.
By submitting your contact details, you agree for us to share your details with our retail partners, who will contact you directly to arrange your appointment. For full details on how your data is shared please review our privacy policy
Customer Reviews
  • CLOUD, getReviews, 12.5ms
  • REVIEWS, PRODUCT
Newsletters Sign Up
