NAC A5
NAC A5
Every link in the hi-fi chain is important. Connections between components, including those to the loudspeakers, are crucial to the performance of any audio system.
NAC A5 is our multi-strand loudspeaker cable, consisting of two separated 4mm2 conductors. Its design is optimised for use with Naim Audio amplifiers and any loudspeakers by ensuring that its capacitance, inductance and resistance are entirely compatible.
We strongly recommend its use, along with our right-angled, twin loudspeaker plugs, which provide a safe, convenient and very effective connection. Even their plating has been the subject of research and development work.
Features
-Twin separated 4mm2 conductors
-Design and build optimised for Naim Audio amplifiers
-Available in black and white
Similar products
JOIN THE COMMUNITY
Receive a sneak preview of the latest audio innovations from Focal and Naim by subscribing to our exclusive newsletters. Be among the first to discover our new products, and receive privileged information straight to your inbox.
