NAP 155 XS Power Amplifier
NAP 155 XS
Accessible high-end power.
The ideal partner for our NAC 152 XS preamplifier or NAC-N 172 XS streaming preamplifier, the NAP 155 XS features a substantial, custom-designed toroidal transformer with separate transformer windings for each output channel. It delivers 60 watts per channel (into 8 ohms) and will become the musical engine of a modern or traditional hi-fi system, whether the source is a digital stream, CD or vinyl.
Features
  • 60W per channel output into 8 ohms
  • Internal power supply to allow direct connection of a NAC 152 XS, NAC 202 or NAC 282 preamplifier
  • Custom-designed toroidal transformer with separate transformer windings for each output channel
Technology & Craft
The NAP 155 XS is flexible enough to be used in most types of systems, both passive and active but retains an unwavering focus on performance.
The heart of the amplifier circuit is a version of the world class NAP 500 with a substantial and very quiet power supply using a custom-designed and manufactured toroidal transformer. Improvements over its predecessor, the NAP 150, include: a new toroidal transformer for improved regulation; separate windings for each channel and preamp; and an up-rated preamp power supply to improve the performance of the preamp.
Product Specification
Audio Inputs
Attribute Name Attribute Value
Analogue Input
1 x 4-pin DIN
Input Impedance
18kΩ
Audio Outputs
Gain
+29dB
Frequency Response
 -3dB at 3Hz - 50kHz
Power Outputs
Naim pre-amplifier
Minimum Load Impedance
THD
0.013%
THD
0.013%
Signal-to-Noise Ratio
100dB
Speaker Outputs
Speaker Outputs
L & R, 4mm “banana” sockets
Power Output
60W/channel, 8Ω
Transient
260VA
Power
Mains Supply
100V, 115V, 230V; 50 or 60Hz
Power Consumption (quiescent)
16VA
Power Consumption
330VA (max.)
Physical
Dimensions (HxWxD)
70 x 432 x 301 mm
Weight
7.9 kg
Shipping Dimensions
200 x 590 x 500 mm
Shipping Weight
10.5 kg
Supplied with
SNAIC
Finish
Front
Brushed and black anodised
Case
Black powder coated
Suggested System
A Naim Retailer will recommend the right system for you, however you may choose to partner the NAP 155 XS with the following as a start:
ND5 XS Network Player
ND5 XS
XS Series
NAT05 XS
NAT05 XS
XS Series
NAC 152 XS
XS Series
CD5 XS cd player
CD5 XS
XS Series
Manuals & Downloads
Newsletters Sign Up
