Connection
Magazine
Uniti Core Hints and Tips
Uniti Core is a fabulous little black box. The only home you need for your carefully guarded music collection, it will rip, store and serve with ease.
Share
Our in-house experts in the Tech Support team have provided some tips on how to make the most of setting up and using your Uniti Core.
Which Drive Should I Use?
Choosing a drive for your Uniti Core can be a bit intimidating, but any 2.5” or 3.5” SATA hard or solid state drive will be fine.  We recommend the Seagate Pipeline/Video 2TB hard disks (HDD) or the Samsung 850 EVO 512GB/1TB solid state drive (SSD) - we have found these to provide the best audio performance.  If you are unsure or have any questions, contact the Tech Support team who will be happy to help.
An important step in setting up your Uniti Core – the music store is where your rips and downloads will live.
Creating a Music Store
To start your music store setup, go to the ‘Settings’ menu and select ‘Manage Music’, followed by ‘Configure music stores’ and then ‘Configure new music store’. Uniti Core will then search for all the possible locations (on both locally attached storage and on network attached storage) that could be used for storing audio files.
For an internal drive or a locally attached USB device, you will need to format the device before it can be used. Formatting will remove any existing data on the drive, so be sure that if there is any data left, you have either copied it elsewhere or you no longer need it.
If you are using a USB attached storage device, you can select the format that you wish to use on that device – this enables you to unplug the device and use it with your computer if you wish to transfer music from your computer directly into the downloads folder on the storage device.  If you are a Windows user you should choose NTFS, if you are a Mac user you should choose HFS+ and if you are a LINUX user you should choose EXT4. Uniti Core will automatically decide the format of any internal drive and NAS shares do not need to be formatted by Uniti Core.
You will be prompted to enter a name for the drive before formatting – this is for your reference, should you have multiple devices as stores. Once you have entered your desired name, touch ‘Done’ and then ‘OK’ to begin formatting the device.  Your drive will then be formatted and all existing data erased. Once formatting is complete, the device is available for use as music storage by Uniti Core.
Playing Music from Uniti Core
Uniti Core can operate as a UPnP™ music server, providing audio files to any UPnP-compatible player on the same network - and it couldn't be easier to do. It also incorporates a digital audio output to allow local playback via the digital input of a hi-fi system. Music can be played locally from internal storage, a network drive or attached USB drives using the Naim app.
Creating a Playlist
Building playlists couldn’t be easier and makes accessing music to suit your mood a one-stop shop. Start populating yours with our simple guide below:
Open the Naim app and touch the Uniti Core icon. Navigate to the track you wish to add, for example - touch ‘Album’ and then find your desired album. Touch the ‘…’ icon next to the track you wish to add.  Before you can add your track to a playlist you will need to create the playlist, so touch ‘New playlist’. Touch the ‘Name’ text area in the bar that appears and enter a name for your playlist using the keyboard.  Then touch ‘Done’ and your track will have been added to the new playlist. If you'd like to add more tracks, touch the ‘…’ icon next to each track you want to add and then touch the playlist you wish to add it to from the menu that pops up, it should appear just below the ‘New playlist’ option. To view your playlists, touch the home button - the house icon and then go to the ‘Playlists’ option and then the desired playlist to see a list of all the tracks within.
Uniti Core Support
The hints and tips we’ve listed are a few examples of how to get the best out of your Uniti Core music server, but each user is and home set up is individual, so we’d love to hear some of your Uniti Core hints and tips. Please send us an email at [email protected].
If you’d like more information on the different setup options, head across to our interactive simulator for a step-by-step guide with imagery or watch our new Uniti Core support video. It will walk you through all the steps for initial setup and show you exactly what you need to get Uniti Core serving music in no time.
Related articles
26 July 2022
Fable today releases her much anticipated debut album Shame, out now via Naim Records.
26 July 2022
Naim Audio, the British hi-fi specialist with 49 years of audio expertise, has added Crestron...
15 June 2022
Fable today unveils new single ‘Onion Brain’, the latest...
16 May 2022
For sensational listening at home, discover a complete, hi-fi system: Focal's Aria K2 926...
24 March 2022
The Devon-based genre-jumping juggernaut that is Fable has announced ‘Shame’, the debut...
