SNAXO 362 Loudspeaker Upgrade
SNAXO 362
Upgrade to active.
Our SNAXO 362 crossover suits three-way loudspeakers, and can be used in tri-amped configurations with three stereo power amplifiers. As with its SNAXO 242 sibling, it can be optimised to suit your needs, even allowing for the output level to each loudspeaker drive unit to be adjusted.
Features
  • Suitable for use with three stereo, or six mono amplifiers
  • Powered by FlatCap XS, HiCap or SuperCap power supply
SNAXO 362 Loudspeaker Upgrade - Rear View
Technology & Craft
The SNAXO 362 is our three-way, 18dB/octave fixed-frequency crossover. It can be used in tri-amped and six-pack systems, with either three stereo or six mono power amplifiers. The output level to each loudspeaker drive unit can be adjusted by means of the cermet potentiometers mounted inside the unit. As with the 2-way SNAXO 242, power is supplied by a FlatCap XS, HiCap or SuperCap power supply.
When ordering a SNAXO, you should specify which loudspeaker model this will be used with, as we tailor the components within each SNAXO for use with specific loudspeakers. For more information contact your local Naim Audio retailer.
Product Specification
Audio Outputs
Attribute Value
Line Outputs Fixed (level)
775mV
Analogue
6 x 4-pin DIN
Minimum Load Impedance
10kΩ
Physical
Attribute Value
Shipping Dimensions
210 x 280 x 410 mm
Dimensions (HxWxD)
87 x 207 x 314 mm
Finish
Attribute Value
Case
Black powder coated
Front
Bead blasted and black anodised
Supplied with
Attribute Value
Supplied with
SNAIC
Power
Attribute Value
Power Supply Options
FlatCap XS, HiCap, SuperCap
Supply Voltage
24V
Manuals & Downloads
Book a Demo
Find Your Nearest Retailer
Please complete the form below to arrange an appointment with your chosen retailer.
By submitting your contact details, you automatically agree for us to share your details with our retail partners, who will contact you directly to arrange your appointment. For full details on how your data is shared please review our privacy policy
Image CAPTCHA
Enter the characters shown in the image.
Newsletters Sign Up
