Wired and Wireless Setup for All Naim Streamers and Systems
Naim Audio products that support streaming or network control can be connected to your home network via Ethernet (wired) or Wi-Fi (wireless). The method depends on the product and your home setup. Below is a guide to connecting each type of Naim device to your network.
Uniti Series (Atom, Star, Nova, Nova PE, Atom HE)
All Uniti models support both wired and wireless connections:
Wired: Connect an Ethernet cable from the rear panel to your router or network switch.
Wireless: Attach the supplied Wi-Fi antenna. Use the Focal & Naim app to select your device, choose your Wi-Fi network, and enter the password.
Mu-so Series (Mu-so 2nd Gen, Mu-so Qb 2nd Gen)
These all-in-one wireless systems also support both connection types:
Wired: Plug an Ethernet cable into the rear port and connect it to your router.
Wireless: During setup, the LED will flash purple. Use the Focal & Naim app to connect to your Wi-Fi network.
Classic and 500 Series Streamers (ND5 XS 2, NDX 2, ND555)
These network players offer wired and wireless options:
Wired: Use the Ethernet port on the rear panel for a stable connection.
Wireless: Attach the Wi-Fi antenna and configure the connection using the Focal & Naim app or front panel display (if available).
For best performance, a wired Ethernet connection is recommended, especially for high-resolution streaming.
Older Naim products like the HDX typically support wired Ethernet only. Some may offer limited Wi-Fi functionality via USB dongles or internal modules.
Unlike some other legacy models, the SuperUniti includes built-in Wi-Fi capability, allowing it to connect wirelessly to your home network.
Refer to the product manual for specific instructions.
Wired connections are preferred for stability and performance.
Uniti Core (Music Server)
The Uniti Core requires a wired Ethernet connection to function properly. It does not support Wi-Fi.
Connect the Ethernet port to your router or switch.
The Core will appear in the Focal & Naim app for control and library management.
Did this article not solve your problem?
JOIN THE COMMUNITY
Receive a sneak preview of the latest audio innovations from Focal and Naim by subscribing to our exclusive newsletters. Be among the first to discover our new products, and receive privileged information straight to your inbox.
By submitting this form, I agree that Focal and/or Naim may send me personalized communications and collect the personal information provided above in order to process my request.
