Customizing device names on your network
When using multiple Naim devices in your home, giving each one a unique name makes it easier to identify and control them, especially when using the Focal & Naim App, streaming services, or voice assistants. This guide explains how to rename your Naim device on your network and what to expect after doing so.
1. Can I Rename My Naim Device?
Yes. Most modern Naim products—including the Uniti Series, Classic Series streamers, and Mu-so systems—allow you to customize the device name that appears on your home network and in the Focal & Naim App.
2. Why Rename Your Device?
Renaming your device helps you:
  • Easily identify it in the Focal & Naim App
  • Distinguish between multiple Naim products on the same network
  • Improve clarity when using multiroom playback
  • Simplify integration with smart home systems
3. How to Rename Your Device
To rename your Naim device:
  1. Open the Focal &Naim App on your smartphone or tablet.
  2. Go to the Rooms screen and select the device you want to rename.
  3. Tap the three dots icon in the top right to access settings.
  4. Navigate to System Settings > Device Name
  5. Enter your preferred name (e.g., “Living Room Nova” or “Bedroom Mu-so”).
  6. Save your changes.
The new name will now appear in the app and on your network.
4. Will the New Name Appear Everywhere?
Yes. Once renamed, the new device name will be visible:
  • In the Focal & Naim App
  • On your home network (e.g., router interface)
  • In streaming services that support device selection (e.g., Spotify Connect, AirPlay, Chromecast)
  • In multiroom setups with other Naim devices
5. Can I Change the Name Again Later?
Absolutely. You can rename your device at any time by repeating the steps above. There’s no limit to how often you can update the name.
6. Troubleshooting Tips
  • If the new name doesn’t appear immediately, try restarting the Focal & Naim App or rebooting your device.
  • Ensure your device is running the latest firmware for full compatibility.
Avoid using special characters or emojis in the device name, as some services may not support them.
JOIN THE COMMUNITY
Receive a sneak preview of the latest audio innovations from Focal and Naim by subscribing to our exclusive newsletters. Be among the first to discover our new products, and receive privileged information straight to your inbox.
