Installing storage on Naim Product
Product Compatibility Overview
Product Category
Models
Internal Storage
USB Storage
NAS (UPnP)
Storage Support
Uniti Series
Uniti Atom, Star, Nova
✗ No
✓ Yes
✓ Yes
✓ Supported
Mu-so Series
Mu-so 2nd Gen, Mu-so Qb 2nd Gen
✗ No
✓ Yes
✓ Yes
✓ Supported
Classic Streamers
ND5 XS 2, NDX 2, ND 555
✗ No
✓ Yes
✓ Yes
✓ Supported
Legacy Streamers
NDX, ND5 XS, SuperUniti, etc.
✗ No
✓ Yes
✓ Yes
✓ Supported
CD Players
CD5si, CD5 XS, CDX2
✗ No
✗ No
✗ No
✗ Not Supported
Amplifiers
NAIT, NAC, NAP Series
✗ No
✗ No
✗ No
✗ Not Supported
Legacy Pre-Streamers
HDX, NS01 (built-in storage, not user-expandable)
✓ Internal only
✗ No
✗ No
✗ Not Expandable
USB Storage Compatibility
All compatible Naim products support USB drives formatted in:
  • FAT32
  • NTFS
  • exFAT
  • EXT4
Drive Type
Supported
Notes
USB Flash Drive
✓ Yes
Ideal for small libraries or playlists
USB HDD / SSD
✓ Yes
Recommended for larger music collections
Tip: Use a high-quality, externally powered USB drive for best performance with large libraries.
Connecting USB Storage
Uniti Series & Classic Streamers :
  1. Plug the USB drive into the front or rear USB port.
  2. Open the Focal &Naim App.
  3. Navigate to Local Music > USB Drive.
  4. The app will index the music and make it available for playback.
Mu-so Series :
  1. Insert the USB drive into the side USB port.
  2. Use the Focal & Naim App or the touch panel to browse and play music.
Mu-so QB Series :
  1. Insert the USB drive into the rear USB port.
Using Network-Attached Storage (NAS)
All modern Naim streamers and all-in-one systems support UPnP streaming from a NAS device.
Setup Steps :
1. Connect your NAS to the same network as your Naim device.
2. Enable UPnP server functionality on the NAS (e.g., Twonky, MinimServer).
3. Open the Focal & Naim App and go to Local Music > UPnP.
4. Select your NAS and browse your music library.
NAS drives are ideal for large libraries and multiroom setups.
Storage Guidelines
  • There is a recommended size limit for USB or NAS Storage: up to 1TB for issue free indexing
  • Organize music files in folders for easier navigation.
  • Use FLAC or WAV formats for best audio quality and compatibility.
  • Avoid using USB hubs or daisy-chained storage devices.
Did this article not solve your problem?
JOIN THE COMMUNITY
Receive a sneak preview of the latest audio innovations from Focal and Naim by subscribing to our exclusive newsletters. Be among the first to discover our new products, and receive privileged information straight to your inbox.
