Naim’s multiroom functionality is designed to deliver seamless, synchronized playback across multiple Naim products.
But what happens when you want to integrate third-party devices into your setup?
This guide explains how Naim’s multiroom system works, its compatibility with other Naim units, and the limitations when it comes to third-party products.
How Naim Multiroom Works
Naim’s multiroom feature allows you to stream music simultaneously to multiple Naim devices over your home network. Using the Focal & Naim app, you can group compatible products and control playback across rooms with ease.
Supported features include:
Synchronised playback across devices
Independent volume control per room
Grouping and ungrouping zones on the fly
Compatibility with Other Naim Products
Multiroom is fully supported across the following Naim product families:
Uniti range (Uniti Atom, Uniti Star, Uniti Nova)
ND series (ND5 XS 2, NDX 2, ND555)
Mu-so range (Mu-so and Mu-so Qb 2nd Generation, Mu-so and Mu-so Qb 1st Generation)
Legacy streamers (NDX, SuperUniti, UnitiLite, Uniti Qute etc)
These products can be grouped together in any combination, allowing for flexible and scalable multiroom setups.
✓ Example: You can group a Uniti Atom in the living room with a Mu-so Qb 2nd Generation in the kitchen and an ND555 in the listening room—all controlled from the same app.
Compatibility with Third-Party Devices
Naim’s multiroom system is not compatible with third-party audio products.
This includes:
Wireless speakers from other brands
Smart speakers (e.g. Sonos, Bose, Apple HomePod)
AV receivers or amplifiers from non-Naim manufacturers
This limitation exists because Naim uses a proprietary multiroom protocol optimized for performance, synchronization, and sound quality within its own ecosystem.
Note: Even if a third-party device supports UPnP, AirPlay, or Chromecast, it cannot be grouped with Naim products in a multiroom configuration using the Focal & Naim app.
Alternatives for Mixed-Brand Setups
If you want to integrate Naim products into a broader smart home or multi-brand audio system, consider these options:
AirPlay 2 : Allows simultaneous playback to multiple AirPlay 2-compatible devices (including Naim) from Apple devices.
Streaming individually : You can stream to each device separately using Spotify Connect, TIDAL Connect, Qobuz Connect, or Chromecast, but without synchronisation.
Final Tips
For the best multiroom experience, use only Naim products within the group.
Keep all devices on the same network and ensure firmware is up to date via the Focal & Naim app.
If you need help designing a multiroom system, consult your local Naim dealer.
Did this article not solve your problem?
JOIN THE COMMUNITY
Receive a sneak preview of the latest audio innovations from Focal and Naim by subscribing to our exclusive newsletters. Be among the first to discover our new products, and receive privileged information straight to your inbox.
By submitting this form, I agree that Focal and/or Naim may send me personalized communications and collect the personal information provided above in order to process my request.
