Streaming music with Naim: sources and compatibility
Supported Streaming Sources
Naim products support a wide range of streaming services and sources, including:
Internet radio
UPnP servers (e.g. from a NAS or computer)
Spotify Connect
TIDAL integrated and TIDAL Connect
Qobuz integrated and Qobuz Connect
AirPlay 2
Chromecast built-in
Bluetooth (aptX HD)
These services are accessible directly from the Focal & Naim app or via native integration on the device.
Streaming from a Mobile Device
Music can be streamed from a smartphone or tablet using:
AirPlay 2 (iOS devices)
Chromecast built-in (Android and iOS)
Bluetooth (from any compatible device)
These methods allow playback from apps such as Apple Music, YouTube, Deezer, and others.
Supported File Resolutions
Naim streaming products support a wide range of audio resolutions:
Up to 32-bit/384kHz PCM
Up to DSD128 (on supported models via UPnP)
File formats supported include WAV, FLAC, AIFF, ALAC, MP3, AAC, and OGG. Playback resolution may vary depending on the source and connection method.
Using a Naim Device with a TV
When connecting a TV via HDMI ARC or optical input, ensure the TV is outputting a stereo signal. Most TVs default to multichannel formats like Dolby Digital, which are not compatible.
To ensure proper audio playback:
Go to your TV’s Audio Output Settings.
Change the format to PCM or LPCM.
Avoid settings like “Auto” or “Dolby,” which may cause distortion, clicking sounds, or silence.
Naim devices are designed to decode two-channel stereo signals only.
JOIN THE COMMUNITY
Receive a sneak preview of the latest audio innovations from Focal and Naim by subscribing to our exclusive newsletters. Be among the first to discover our new products, and receive privileged information straight to your inbox.
