Supported audio formats on Naim units
Naim products are engineered to deliver high-fidelity sound across a wide range of digital audio formats. Whether you're streaming music, playing files from a USB drive, or accessing a networked library, your Naim unit supports a variety of file types and sample rates to ensure the best possible listening experience.
This guide outlines the supported formats for each major Naim product, including streamers, all-in-one systems, and wireless speakers.
Uniti Core
The Uniti Core is a music server and CD ripper designed to store and serve high-resolution audio files across your network.
Supported formats:
  • WAV: up to 32-bit/384kHz
  • FLAC: up to 24-bit/384kHz
  • AIFF: up to 24-bit/384kHz
  • ALAC: up to 24-bit/384kHz
  • MP3, AAC, Ogg Vorbis, WMA: up to 48kHz
Uniti Nova, Uniti Star, Uniti Atom
The Uniti Nova is a high-performance all-in-one player with broad format support.
The Uniti Star combines streaming, CD playback, and amplification in one unit.
The Uniti Atom is a compact all-in-one player with streaming and amplification capabilities.
Supported formats:
  • DSD: 64 and 128 (via UPnP and USB)
NDX 2, ND5 XS2, ND555
The NDX 2 is a high-end network player with extensive format compatibility.
The ND5 XS 2 is a streamlined network player with support for high-resolution formats.
The ND555 is Naim’s reference streamer, offering the highest level of audio performance and format support.
Supported formats:
Mu-so 2nd Generation
The Mu-so 2nd Generation Mu-so Qb 2nd Generation are wireless speakers systems with support for high-resolution streaming.
Supported formats:
Final Notes
  • Streaming services like TIDAL, Qobuz, and Spotify are supported across most Naim units via the Focal & Naim app.
  • UPnP and USB playback offer the highest resolution support, especially for DSD files.
  • Firmware updates may expand format compatibility or improve playback performance—check regularly via the app.
JOIN THE COMMUNITY
Receive a sneak preview of the latest audio innovations from Focal and Naim by subscribing to our exclusive newsletters. Be among the first to discover our new products, and receive privileged information straight to your inbox.
