Naim streaming products support USB storage devices for music playback, but compatibility depends on the format of the drive, the file types, and the device model. This guide outlines what works, what doesn’t, and how to troubleshoot common issues.
Supported devices and Formats
Naim products support a wide range of USB storage devices, including:
USB flash drives
Portable hard drives (self-powered or externally powered)
To ensure compatibility:
Format the drive as FAT32, exFAT, or NTFS.
Avoid using drives with multiple partitions or encrypted volumes.
Ensure the drive is not overloaded with too many files or folders, which can slow down indexing.
Note: Some older Naim models may only support FAT32.
Supported File Types
The USB input supports playback of the following audio formats:
WAV
FLAC
AIFF
ALAC
MP3
AAC
OGG
High-resolution files (up to 24-bit/384kHz) are supported on most modern Naim streamers and Uniti systems.
Accessing USB Content in the Focal & Naim App
Once a compatible USB device is connected:
Open the Focal & Naim app.
Select your device from the My Devices screen.
Navigate to the USB input.
Browse and play music directly from the drive.
The app will scan the USB device and display its contents in a structured format. You can browse by folder, artist, album, or genre (if metadata is available).
The USB input is designed for:
Direct music playback from USB storage devices.
Firmware updates on legacy systems (via Mini-USB, not USB-A).
It is not intended for use with USB DACs, smartphones in data mode, or streaming from mobile apps.
JOIN THE COMMUNITY
Receive a sneak preview of the latest audio innovations from Focal and Naim by subscribing to our exclusive newsletters. Be among the first to discover our new products, and receive privileged information straight to your inbox.
