What is the maximum size HDD/ flash drive that can be used with Naim product?
USB Storage Compatibility Across the Product Range
For optimal compatibility and performance, Naim recommends using USB storage devices up to 1TB for SSD hard drives and 256GB for flash drives.
Compatibility depends primarily on the file system format, the number of tracks, and the device generation.
Supported Drive Types
The following USB storage devices are supported:
USB flash drives
Self-powered USB hard drives
Bus-powered USB hard drives
File System Format
To ensure compatibility:
Use FAT32 for universal support across all products.
exFAT is supported on newer products running firmware version 3.4 or later.
NTFS is supported on some newer models, such as the Uniti Core.
Older products like the first-generation Mu-so and NDS require FAT32 formatting.
Track Count and Performance
For optimal performance:
Keep the number of tracks on the drive below 100,000.
Avoid deep folder structures or excessive metadata, which can slow down indexing or cause incomplete scans.
Product-Specific Notes
Product Range
Drive Type Support
File System Support
Size Limit
Uniti Series
USB stick, HDD (self/bus)
FAT32, exFAT (fw 3.4+), NTFS
USB sticks: up to 128–256GB depending on model
Mu-so 2nd Gen
FAT32, exFAT
No strict size limit, but <100,000 tracks recommended (~2TB practical max)
ND5 XS 2 / NDX 2
Uniti Core
USB & internal HDD/SSD
FAT32, exFAT, NTFS, HFS+
Supports internal/external drives up to 8TB, tested with up to 100,000 tracks
Legacy Products
USB stick only (recommended)
FAT32 only
Limited to FAT32, recommended ≤256GB for reliable performance
JOIN THE COMMUNITY
Receive a sneak preview of the latest audio innovations from Focal and Naim by subscribing to our exclusive newsletters. Be among the first to discover our new products, and receive privileged information straight to your inbox.
