What upgrades can I use with my streamer?
Naim streamers are designed to deliver exceptional audio performance and evolve with your system over time. Whether you're using a flagship model or an all-in-one player, there are several upgrade paths available to enhance sound quality, connectivity, and overall experience.
This guide outlines the most relevant upgrades and accessories compatible with each Naim streaming product.
ND555
The ND555 is Naim’s reference network player, engineered for ultimate musical performance. To unlock its full potential, consider the following upgrades:
  • 555 PS DR Power Supply
     One 555 PS DR is required to operate the ND555. Adding a second unit allows for complete separation of digital and analogueue power supplies, significantly enhancing performance.
  • Naim Fraim
     A dedicated equipment support system that isolates vibrations and improves clarity and timing.
  • Super Lumina Interconnects
     Designed to deliver the purest signal path between components.
NDX 2
The NDX 2 offers high-end streaming with flexibility for future upgrades:
  • XPS DR or 555 PS DR Power Supply
     Adding an external power supply improves dynamics, detail, and musicality.
  • Naim Fraim
     Enhances mechanical isolation and system synergy.
     Optimised for use with Naim’s reference-level components.
ND5 XS 2:
The ND5 XS 2 is a streamlined network player with several upgrade options:
  • Naim Fraim: Improves mechanical isolation and clarity.
  • High-Quality Interconnects: Upgrading to better cables can refine detail and reduce noise.
  • Power Supply Upgrades: Not supported with this model.
Uniti Nova
The Uniti Nova is a powerful all-in-one player with integrated amplification. While it doesn’t support external power supplies, it can still benefit from:
  • Naim Fraim or Fraim Lite
     Improves mechanical isolation and system performance.
  • Super Lumina Speaker Cables
     Enhances signal purity and musical expression.
  • External Storage
     Connect USB drives or NAS devices for expanded music libraries.
Uniti Star
The Uniti Star combines streaming, amplification, and CD playback. Upgrade options include:
     Reduces vibration and improves clarity.
     Delivers enhanced signal transmission.
  • External Storage
     Supports USB and network-attached storage for large music collections.
Uniti Atom
The compact Uniti Atom benefits from similar upgrades:
     Enhances mechanical stability.
     Improves signal flow and musical detail.
  • External Storage
     USB and NAS compatibility for flexible music access.
Mu-so 2nd Generation
The Mu-so 2nd Generation is a wireless speaker system with audiophile DNA. While it doesn’t support hardware upgrades, you can still enhance its performance:
  • Firmware Updates
     Delivered via the Focal & Focal & Naim app to improve features and stability.
Mu-so Qb 2nd Generation
The Mu-so Qb 2nd Generation offers the same upgrade paths as its larger sibling:
  • Firmware Updates
     Keep your system up to date via the Focal & Focal & Naim app.
Final Tips
  • Firmware Updates: All Naim streamers benefit from regular firmware updates. Use the Focal & Naim app to check for and install the latest versions.
  • System Synergy: Consider how each component interacts with others in your setup. Matching power supplies, cables, and supports can make a significant difference.
  • Dealer Support: For optimal results, upgrades should be installed or recommended by an authorised Naim dealer.
JOIN THE COMMUNITY
Receive a sneak preview of the latest audio innovations from Focal and Naim by subscribing to our exclusive newsletters. Be among the first to discover our new products, and receive privileged information straight to your inbox.
